Cordless Tools
DREMEL® VersaFlame (2200-4)
Butane torch – The most versatile stationary burner for both DIY and hobby projects
Included accessories allow a variety of creative applications: soldering, shrinking, welding, etc.
Integrated ignition button for easy startup, no independent ignition tool required
Variable temperature and flame control for versatile use in both torch and flame mode
Premium quality for long life, durability
Filling valve for quick recharge
£40.00*
RRP incl. VAT
The Dremel VersaFlame is the only stationary burner that safely supports open flame use and comes with a catalyst and soldering head, making it the most versatile stationary burner in the market today, especially for DIY applications. The Dremel VersaFlame is powered by liquid butane gas for quick heat-up and fast recharge. Applications for use include: soldering, shrinking, welding, etc.
Example of usage
Technical details for DREMEL® VersaFlame (2200-4)
Technical specifications
Weight
0,227 kg
17 cm
6 cm
Depth
11 cm
Battery technology
Ignition
Piëzo
Burn time
75 min
Tank capacity
42ml / 22g
Temperature
1200C (open air)680 - 1000C (hot air)550C (tips)
Precision tip
Dual temperature
Removable cord
Drip control
Delivery details: DREMEL® VersaFlame (2200-4)
Dremel VersaFlame
Catalyst
Soldering tip
Flame extension piece
Deflector
Soldering tin with blue cap
Soldering sponge + sponge box
Instruction manual
Tin storage case
Product box length, 17.7 cm
Product box height, 33 cm
Product box width, 5.5 cm
Gross weight, 0,90 kg
F0132200JA
8710364042081
8710364042081
