Butanetools
DREMEL® VersaFlame (2200-5)
Butanetools
Multifunctional Butane Torch
  • Comes with five accessories for soldering, welding, heat blowing, heat deflecting, and flame diffusing.
  • Features a gas tank with a 22g capacity for up to ± 75 minutes of use at maximum capacity.
  • Allows for easy adjustment of both the flame size and temperature with variable temperature control.
51 GBP
The Dremel VersaFlame is a versatile, cordless butane torch equipped with set of accessories for a wide range of applications. With adjustable flame control, it seamlessly transitions between tasks, from delicate soldering to robust heating. The torch's large gas tank ensures extended use, while its design includes practical features like an integrated ignition and flame lock for continuous operation. Ideal for both professional and hobbyist use, the VersaFlame is designed for efficiency and ease, making it an indispensable tool in any toolkit.
Comprehensive Versatility
The Dremel VersaFlame is an all-encompassing tool equipped with a variety of accessories designed to handle a wide range of tasks with precision and ease. Included in the package are a catalyst, two soldering tips, a flame extension piece, and a deflector, each serving distinct functions to maximize the tool's utility across various applications. Catalyst generates hot air of up to 680°C, ideal for melting plastics and other heat-sensitive materials. Soldering tips allow for regular soldering activities, from electronics to small metalwork. The kit also includes a comprehensive soldering set complete with solder, a sponge, and tins, equipping you for extensive soldering tasks. Flame extension piece produces hot air of approximately 1000°C, enabling the heating of larger surfaces quickly and evenly. When used with the flame extension piece, the deflector directs the heat in a more controlled manner, making it ideal for shrinking heat-sensitive insulation around electrical wiring.
Extended Operating Time and Convenience
The Dremel VersaFlame is optimized for both extended use and ease of operation, ensuring you can focus on your projects without frequent interruptions. At the heart of its design is a large gas tank, boasting a capacity of 22g, which supports up to ±75 minutes of continuous operation at maximum capacity. This generous capacity minimizes the need for frequent refills, allowing you to maintain a steady workflow. Refilling the tank is straightforward and quick—simply watch for the escape of liquid butane gas through the filling valve to know the tank is full. For safety and efficiency, it is important to follow the detailed instructions provided in the manual during the refilling process.
Precise Temperature Management
The Dremel VersaFlame offers adjustable flame control for precise temperature management across various applications. With settings ranging from 550°C for the soldering tip to 1200°C for an open flame, you can easily tailor the heat intensity to your project's needs. The torch heats up immediately when using an open flame, and the soldering tip is ready in about 25 seconds, allowing for efficient and continuous work without unnecessary delays. This feature ensures optimal performance whether you're engaging in delicate soldering or requiring high heat for larger tasks.
Reliable and User-Friendly Design
The Dremel VersaFlame butane torch uses standard lighter liquid butane gas, which is readily available and easy to refill. Its cordless design allows for unrestricted movement during use. The torch includes an attachable base that helps it stay upright when not in use, providing convenience and facilitating easy storage. An integrated ignition simplifies the start-up process, eliminating the need for a separate ignition tool. Additionally, the torch is equipped with an ignition lock to prevent accidental activation and a flame lock for maintaining a continuous flame during extended use, making the VersaFlame both dependable and easy to operate across various projects.
Tank capacity of 22 grams: Longer use; full tank lasts up to 75 min at maximum capacity
Precise flame: Allows for detailed open flame work
Weight
0.227 kg
17 cm
6 cm
Depth
11 cm
Battery technology
Ignition
Piëzo
Burn time
75 min
Tank capacity
34ml / 20g
Temperature
1200C (open air)680 - 1000C (hot air)550C (tips)
4053423300611
F0132200JD
User Manuals
Your Selection
Dremel versaflame with 4 accessories
DREMEL® VersaFlame (2200-4)
Order number: F0132200JA
EAN Code: 8710364042081
49.48 GBP
Product details
