Retired Products
Retired Products
Multifunctional Butane Soldering Iron – The cordless 6-in-1 gas-torch for hot cutting, pyrography and more
- Included 6 accessories allow a variety of creative applications that require precision on different materials: soldering, pyrography, hot cutting, heat embossing, welding and more
- Variable temperature setting allows detailed and intricate finishing for your DIY project
- Integrated ignition trigger for easy startup - no independent ignition tool required
The Dremel VersaTip is the ideal soldering torch for people engaged in creative and detailed projects that require precision and versatility combined with portability. It comes with 6 interchangeable tips which makes it the perfect butane tool for various heat applications: soldering, heat embossing, hot cutting, welding, pyrography, paint removal and more. The variable temperature setting ensures you maximum flexibility for the magnitude of all applications.
Versatile: one tool for 6 different applications
Powered by liquid butane gas: use anytime anywhere
Variable temperature setting: select the right temperature for your project
