DREMEL® VersaTip (2000-7 Hobby)
Butanetools
Arts & Crafts
Butanetools
Arts & Crafts
Multifunctional Butane Soldering Iron For Creatives & Crafters
  • 7 tips: Great for soldering, pyrography, hot cutting, heat embossing, paint removal and welding.
  • Powered by liquid butane gas with a short heat up time and quick recharge.
  • Achieve the desired precise finishing results due to the variable temperature setting.
Smooth Handling
The Dremel VersaTip is a versatile, cordless soldering iron that operates on butane gas, suitable for a range of applications from soldering to pyrography. It offers variable temperature control, a flame lock for continuous use, and a lock to prevent mishaps. The Dremel VersaTip offers simple operation, suitable for users at any skill level. Its cordless design enhances mobility. The tool features an integrated ignition trigger for quick startups, eliminating the need for a separate ignition tool. A lock also helps prevent accidental ignition. The tool is powered by commonly available lighter gas fuel, ensuring easy access to refills. Refilling the tank is quick and easy, requiring only a few seconds. These features combine to ensure a smooth and hassle-free experience.
Comprehensive Accessory Kit
The tool includes seven accessories: a soldering tip, hot cutting knife, shaping knife, pyrography tip, wide flame head, hot air tip, and deflector, each designed for targeted applications such as pyrography, cutting, and heating. These accessories are complemented by a soldering set that includes solder, a sponge, tins, and wrenches, equips you for soldering tasks. After use, the protective cap ensures safe cooling and storage, preventing damage and extending the lifespan of the tool.
Efficient Temperature and Fuel Management
Heat-up time is instant for open flame use, and approximately 25 seconds with tips attached. You can control the operating temperatures between 550°C and 1200°C, allowing adjustments to the temperature and size of the flame as needed. The soldering iron provides ±45 to ±90 minutes of operation per full tank, depending on the flame size and frequency of use. Tank refills are fast and simple, requiring only a few seconds to complete. Users can easily determine that the tank is full when liquid butane gas escapes through the filling valve. It is important to read the safety instructions before refilling to ensure proper handling and use. Note: Butane gas is not included.
Continuous Operation
Engage the flame lock feature to keep the torch burning steadily, simplifying longer projects. This is especially useful for tasks that require sustained heat.
Versatile: one tool for 6 different applications
Powered by liquid butane gas: use anytime anywhere
Variable temperature setting: select the right temperature for your project
Weight
0,135 kg
2.5 cm
Depth
2.5 cm
Battery technology
Ignition
Piëzo
Burn time
90 min
Tank capacity
12ml / 7g
Temperature
1200C (open air) 680C (hot air) 550C (tips)
4053423300574
F0132000KF
User Manuals
Your Selection
VersaTip with 7 accessories
DREMEL® Versatip (2000-7)
Order number: F0132000JD
EAN Code: 4053423300543
47 GBP
Product details
