Carving/Engraving/Routing
Engraving Bit (194DM)
Engraving  Bit
Engraving  Bit
Engraving  Bit Engraving  Bit
Cylindrical-shaped Dremel Max carving bit for wood and more
  • Dremel Max carving accessory for demanding creative or functional DIY projects that require detailed material removing
  • Delivers maximum durability and lasting performance
  • Coated with Titanium Nitride to last 2 times longer than the standard bit
  • Ideal for applications like carving, engraving or freehand routing in a wide range of materials like wood, plastics and soft metals
  • Contents: 2x Dremel® Max Carving Bit 3.2 mm (194DM)
£9.98* RRP incl. VAT
The Dremel® Max accessory line, designed by our engineers, provides maximum durability and lasting performance. The heavy-duty Dremel Max Carving Bit 194DM is coated in Titanium Nitride to last 2 times longer than the standard, non-coated accessory.
What can you do with it?
The 3.2 mm high-speed cutter works well for detailed material removal in applications like shaping, carving, engraving, hollowing, precision cutting, grooving, slotting, inlaying, making tapered holes or freehand routing. The cylinder shape of the carving bit allows for deep removal of material, cuts flat areas, round edges and makes stop cuts and V-cuts. The accessory tip makes flat bottom slots and grooves, flat side cuts, and makes V-cuts when held at 45-degrees.
How to use:
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. Have a look at the icon or the video to check out the result first, or grab a piece of scrap material before diving into your DIY project.
Expand your possibilities with these attachments: Flexible Shaft (225); Flex-Shaft Tool Holder (2222); Detailer's Grip Attachment (577); Multi-Vise (2500)
Recommended speed (RPM):
Aluminium 30.000
Brass 30.000
Copper 30.000
Hardwood 35.000
Softwood 20-25.000
Plastic 35.000
Steel 20-25.000
Example of usage
Technical details for Engraving Bit (194DM)
  • Veneered woods Veneered woods
  • Softwood Softwood
  • Leather Leather
  • Plywood Plywood
  • Laminates Laminates
  • Chipboard Chipboard
  • Brick Brick
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Carbon Carbon
Technical specifications
Shank diameter
Working diameter
Accessory length
Height
Package Contents
2 pieces
Dremel MAX Accessories
Dremel MAX Accessories - Maximum Durability. Lasting Performance
Get more information about the complete program.
Variations
Delivery details: Engraving Bit (194DM)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
26150194DM
8710364082780
Recommended products:
Multipurpose Set
£18.00* RRP incl. VAT
