Carving / Engraving
Engraving Bit DREMEL® MAX (194DM) 2 pieces
Carving / Engraving
Cylindrical-shaped Dremel Max carving bit for wood and more
- Dremel Max carving accessory for demanding creative or functional DIY projects that require detailed material removing
- Delivers maximum durability and lasting performance
- Coated with Titanium Nitride to last 2 times longer than the standard bit
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
The Dremel® Max accessory line, designed by our engineers, provides maximum durability and lasting performance. The heavy-duty Dremel Max Carving Bit 194DM is coated in Titanium Nitride to last 2 times longer than the standard, non-coated accessory.
What can you do with it?
The 3.2 mm high-speed cutter works well for detailed material removal in applications like shaping, carving, engraving, hollowing, precision cutting, grooving, slotting, inlaying, making tapered holes or freehand routing. The cylinder shape of the carving bit allows for deep removal of material, cuts flat areas, round edges and makes stop cuts and V-cuts. The accessory tip makes flat bottom slots and grooves, flat side cuts, and makes V-cuts when held at 45-degrees.
How to use:
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. Have a look at the icon or the video to check out the result first, or grab a piece of scrap material before diving into your DIY project. Expand your possibilities with these attachments: Flexible Shaft (225); Flex-Shaft Tool Holder (2222); Detailer's Grip Attachment (577); Multi-Vise (2500)
Recommended speed (RPM):
Aluminium 30.000 Brass 30.000 Copper 30.000 Hardwood 35.000 Softwood 20-25.000 Plastic 35.000 Steel 20-25.000
- Cylindrical-shaped Dremel Max carving bit for wood and more
High Speed Cutter 2,0 mm (193-2) 2 pieces
- Medium sized cylindrical shaped head. Detailed shaping of e.g. wood.
High Speed Cutter 3,2 mm (118-2) 2 pieces
- Smallest triangular shaped head. Shape and create V-grooves in e.g. wood.
High Speed Cutter 4,8 mm (192-2) 2 pieces
- Medium sized ball shaped head. Carve and engrave in e.g. wood
High Speed Cutter 5,6 mm (196-2) 2 pieces
- Medium sized cylindrical shaped head. Shape of e.g. wood.
High Speed Cutter 6,4 mm (117-2) 2 pieces
- Carve and engrave in curved and straigh material like wood
High Speed Cutter 6,4 mm (125-2) 2 pieces
- Largest triangular shaped head. Shape and create V-grooves in e.g. wood.
High Speed Cutter 7,2 mm (134-2) 2 pieces
- Carve and remove a lot of material like wood
High Speed Cutter 7,8 mm (114-2) 2 pieces
- Largest ball shaped head. Carve and engrave in e.g. wood
High Speed Cutter 7,8 mm (115-2) 2 pieces
- Largest cylindrical shaped head. Carve and engrave in e.g. wood
High Speed Cutter 7,8 mm (144-2) 2 pieces
High Speed Cutter 9,5 mm (199-2) 2 pieces
- Create small grooves and detailed cuts in e.g. wood
- 2x Dremel® Max Carving Bit 3.2 mm (194DM)
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
