Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Carving / Engraving
Engraving Cutter 0,8 mm (108-3) 3 pieces
Carving / Engraving
See all variations
10.2 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Glass fibre reinforced plastics
Veneered woods
Foam boards
Leather
Fiberboard
Laminates
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
What can you do with it?
Engraving cutter bit especially designed for detailed carving, routing and engraving with a Dremel Multi Tool.
How to use?
Fits with all Dremel Multi Tools or other 3,2mm shank size Multi Tools. For better control and more precision, use with Dremel Detailer's Grip Attachment (577).
Materials to use on
Suitable for use on wood and wood-like materials, metal, plastic, leather, plexiglass, fiberboard, rubber, carbon, chipboard, laminate, foam boards.
Recommended speed
Wood 20.000 –30.000 RPM Metal 15.000-20.000 RPM Plastic 15.000–20.000 RPM
Shank diameter
Working diameter
Accessory length
Package contents
Price
26150108JA
0.8 mm
45.0 mm
3 pieces
£10.00*
  • Smallest Cylindrical shaped head for very detailed carving on e.g. wood
26150105JA
0.8 mm
45.0 mm
3 pieces
£9.00*
Engraving Cutter 0,8 mm (105-3) 3 pieces
  • Smallest ball shaped head for very detailed carving, engraving on e.g. wood
26150106JA
1.6 mm
39.0 mm
3 pieces
£9.00*
Engraving Cutter 1,6 mm (106-3) 3 pieces
  • Small ball shaped head for detailed carving, engraving on e.g. wood
26150107JA
2.4 mm
38.0 mm
3 pieces
£9.00*
Engraving Cutter 2,4 mm (107-3) 3 pieces
26150110JA
1.9 mm
45.0 mm
3 pieces
£9.60*
Engraving Cutter 1,9 mm (110-3) 3 pieces
  • Small Cylindrical shaped head for very detailed carving on e.g. wood
26150111JA
0.8 mm
45.0 mm
3 pieces
£10.00*
Engraving Cutter 0,8 mm (111-3) 3 pieces
  • Smallest long Cylindrical shaped head, for very detailed carving on e.g. wood
26150113JA
1.6 mm
45.0 mm
3 pieces
£11.00*
Engraving Cutter 1,6 mm (113-3) 3 pieces
  • Small long Cylindrical shaped head, for very detailed carving on e.g. wood
Shank diameter
Working diameter
0.8 mm
Accessory length
45.0 mm
High Speed Steel
Shape
Cylinder
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
45.0 mm
Maximum RPM
35,000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044795
26150108JA
3 pieces Engraving Cutter 0,8 mm with the smallest Cylindrical shaped head for very detailed carving on wood
Delivery details
  • 3 pcs
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
10.2 GBP
