Retired Products
Carving / Engraving
Engraving Cutter 0,8 mm (111-3) 3 pieces
Retired Products
Carving / Engraving
See all variations
7.74 GBP
Payment options
Glass fibre reinforced plastics
Veneered woods
Foam boards
Leather
Fiberboard
Laminates
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
Shank diameter
Working diameter
Accessory length
Package contents
Price
26150111JA
0.8 mm
45.0 mm
3 pieces
£10.00*
- Smallest long Cylindrical shaped head, for very detailed carving on e.g. wood
Order number26150111JA
EAN-Code8710364044818
26150105JA
0.8 mm
45.0 mm
3 pieces
£9.00*
Engraving Cutter 0,8 mm (105-3) 3 pieces
- Smallest ball shaped head for very detailed carving, engraving on e.g. wood
Order number26150105JA
EAN-Code8710364044764
26150106JA
1.6 mm
39.0 mm
3 pieces
£9.00*
Engraving Cutter 1,6 mm (106-3) 3 pieces
- Small ball shaped head for detailed carving, engraving on e.g. wood
Order number26150106JA
EAN-Code8710364044771
26150107JA
2.4 mm
38.0 mm
3 pieces
£9.00*
Engraving Cutter 2,4 mm (107-3) 3 pieces
Order number26150107JA
EAN-Code8710364044788
26150108JA
0.8 mm
45.0 mm
3 pieces
£10.00*
Engraving Cutter 0,8 mm (108-3) 3 pieces
- Smallest Cylindrical shaped head for very detailed carving on e.g. wood
Order number26150108JA
EAN-Code8710364044795
26150110JA
1.9 mm
45.0 mm
3 pieces
£9.60*
Engraving Cutter 1,9 mm (110-3) 3 pieces
- Small Cylindrical shaped head for very detailed carving on e.g. wood
Order number26150110JA
EAN-Code8710364044801
26150113JA
1.6 mm
45.0 mm
3 pieces
£11.00*
Engraving Cutter 1,6 mm (113-3) 3 pieces
- Small long Cylindrical shaped head, for very detailed carving on e.g. wood
Order number26150113JA
EAN-Code8710364044825
Shank diameter
Working diameter
0.8 mm
Accessory length
45.0 mm
High Speed Steel
Shape
Cylinder
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
45.0 mm
Maximum RPM
35,000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044818
26150111JA
EAN Code8710364044818
Delivery details- 3 pcs
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
7.74 GBP
