Carving / Engraving
Engraving Cutter 1,6 mm (106) 3 pieces
Carving / Engraving
See all variations
9 GBP
Glass fibre reinforced plastics
Veneered woods
Foam boards
Leather
Fiberboard
Laminates
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
Shank diameter
Working diameter
Accessory length
Package contents
Price
26150106JA
1,6 mm
3 pieces
£9.00*
  • Small ball shaped head for detailed carving, engraving on e.g. wood
26150113JA
1,6 mm
45,0 mm
3 pieces
£11.00*
Engraving Cutter 1,6 mm (113) 3 pieces
  • Small long Cylindrical shaped head, for very detailed carving on e.g. wood
26150110JA
1,9 mm
45,0 mm
3 pieces
£9.60*
Engraving Cutter 1,9 mm (110) 3 pieces
  • Small Cylindrical shaped head for very detailed carving on e.g. wood
26150111JA
0,8 mm
45,0 mm
3 pieces
£10.00*
Engraving Cutter 0,8 mm (111) 3 pieces
  • Smallest long Cylindrical shaped head, for very detailed carving on e.g. wood
26150107JA
2,4 mm
3 pieces
£9.00*
Engraving Cutter 2,4 mm (107) 3 pieces
26150108JA
0,8 mm
45,0 mm
3 pieces
£10.00*
Engraving Cutter 0,8 mm (108) 3 pieces
  • Smallest Cylindrical shaped head for very detailed carving on e.g. wood
26150105JA
0,8 mm
45,0 mm
3 pieces
£9.00*
Engraving Cutter 0,8 mm (105) 3 pieces
  • Smallest ball shaped head for very detailed carving, engraving on e.g. wood
Shank diameter
Working diameter
1,6 mm
Accessory length
High Speed Steel
Shape
Ball
Mandrel use
No Mandrel Needed
Height
Maximum RPM
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044771
26150106JA
Dremel accessory 106_Engraving Cutter 1,6 mm
Delivery details
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 1.3 cm
9 GBP
