Carving Engraving
Engraving Cutter 1,9 mm (110)
Engraving Cutter 1,9 mm Engraving Cutter 1,9 mm
Small Cylindrical shaped head for very detailed carving on e.g. wood
£8.80* RRP incl. VAT
Example of usage
Technical details for Engraving Cutter 1,9 mm (110)
  • Glass fibre reinforced plastics Glass fibre reinforced plastics
  • Veneered woods Veneered woods
  • Foam boards Foam boards
  • Leather Leather
  • Fiberboard Fiberboard
  • Laminates Laminates
  • Plywood Plywood
  • Softwood Softwood
  • Chipboard Chipboard
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Carbon Carbon
Technical specifications
Shank diameter
Working diameter
1,9 mm
Accessory length
45,0 mm
Height
45,0 mm
Maximum RPM
Maximum RPM
Special|Glass fibre reinforced plastics 1/min
Package Contents
3 pieces
Variations
Delivery details: Engraving Cutter 1,9 mm (110)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
26150110JA
8710364044801
Recommended products:
Multipurpose Set
£19.00* RRP incl. VAT
