Carving / Engraving
Engraving Cutter 2,4 mm (107-3) 3 pieces
Carving / Engraving
Small ball shaped head for detailed carving, engraving on e.g. wood
- Ideal for shaping, hollowing, grooving, slotting, inlaying and making tapered holes
- For wood, fiberglass, plastic and soft materials
- Use higher speeds for hard woods, slower speeds for metals and very slow speeds for plastics
Glass fibre reinforced plastics
Veneered woods
Foam boards
Leather
Fiberboard
Laminates
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
What can you do with it?
Engraving cutter bit especially designed for detailed carving, routing and engraving with a Dremel Multi Tool.
How to use?
Fits with all Dremel Multi Tools or other 3,2mm shank size Multi Tools. For better control and more precision, use with Dremel Detailer's Grip Attachment (577).
Materials to use on
Suitable for use on wood and wood-like materials, metal, plastic, leather, plexiglass, fiberboard, rubber, carbon, chipboard, laminate, foam boards.
Recommended speed
Wood 20.000 –30.000 RPM Metal 15.000-20.000 RPM Plastic 15.000–20.000 RPM
- Small ball shaped head for detailed carving, engraving on e.g. wood
Engraving Cutter 1,6 mm (113-3) 3 pieces
- Small long Cylindrical shaped head, for very detailed carving on e.g. wood
Engraving Cutter 1,9 mm (110-3) 3 pieces
- Small Cylindrical shaped head for very detailed carving on e.g. wood
Engraving Cutter 0,8 mm (111-3) 3 pieces
- Smallest long Cylindrical shaped head, for very detailed carving on e.g. wood
Engraving Cutter 0,8 mm (108-3) 3 pieces
- Smallest Cylindrical shaped head for very detailed carving on e.g. wood
Engraving Cutter 0,8 mm (105-3) 3 pieces
- Smallest ball shaped head for very detailed carving, engraving on e.g. wood
Engraving Cutter 1,6 mm (106-3) 3 pieces
Suitable Dremel devices
Retired Products
Multi-Tools
- 3 pcs
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
