Collets / Mandrels / Miscellaneous
EZ SpeedClic accessories
EZ SpeedClic Mandrel (SC402)
The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. It makes accessory changes 6X faster than using a standard mandrel.
  • First patented system of its kind
  • The patented EZ Speedclic system making accessory changes 6X faster than using a standard mandrel by eliminating the need for a screw
  • Compatible with all Dremel Multi-Tools
14.5 GBP
Package contents
Price
2615S402JB
1 piece
£14.50*
26150401JA
3 pieces
£5.70*
Mandrel (401) 3 pieces
  • Mandrel tomount different cleaning and polishing accessories
26150402JA
4 pieces
£9.60*
Mandrel (402) 4 pieces
  • Mandrel to mount different accessories to use with your Dremel Multi-Tool
2615448532
1 piece
£14.20*
Collets (3,2 mm) including a collet nut (4485)
  • Improve the grip for bits in our Multi-Tool line
2615448632
1 piece
£16.00*
Multi Chuck (0.8-3.2 mm) (4486)
  • Provides quick and easy tool-free accessory changes
Shank diameter
Accessory length
Mandrel use
No Mandrel Needed
11,0 mm
Maximum RPM
11,0 mm
Height
Suitable Dremel devices
Retired Products
DREMEL® 7750 (7750-10)
Multi-Tools
8710364042838
2615S402JB
Dremel Mandrel Sc402
Delivery details
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
14.5 GBP
