Accessory Kits
EZ SpeedClic Multipurpose Accessory Set (SC725)
Accessory Kits
Multipurpose kit with 70 high quality EZ SpeedClic accessories for various applications and materials
  • All-purpose accessory set includes 70 bits for cutting, polishing, sanding, cleaning and more!
  • Accessory set includes the patented EZ Speedclic accessory system.
  • The storage case allows you to conveniently store your Dremel accessories.
58 GBP
Hardwood
Softwood
Plastic
Soft Metal
Metal pipes
Stainless Steel
Plywood
The EZ SpeedClic Multipurpose Accessory Set contains 70 high quality genuine EZ SpeedClic accessories which allow for quick, easy and keyless accessory changes. EZ SpeedClic is Dremel's unique quick-change system for rotary tool accessories. With this accessory set you can tackle a wide range of applications like cutting, sanding, grinding, polishing in a variety of different materials. The storage case allows you to conveniently store your Dremel accessories.
Package contents
Price
2615E725JA
1 piece
£56.00*
  • Multipurpose kit with 70 high quality EZ SpeedClic accessories for various applications and materials
2615S690JA
1 piece
£28.00*
EZ SpeedClic Cutting Accessory Set (SC690)
  • Set of 10 EZ SpeedClic cutting wheels + mandrel for cutting in metals and plastics
26150660JA
1 piece
£46.00*
DREMEL® Multipurpose Router Bit Set (660)
  • Set of 7 routing accessories to rout in a variety of materials
2615C681JA
1 piece
£17.50*
Woodworking Set (681)
  • 20 pieces Woodworking Accessory Set
2615C682JA
1 piece
£22.00*
Glass Etching Set (682)
  • 8 pieces Glass Etching Accessory Set
26150684JA
1 piece
£19.00*
Cleaning / Polishing Set (684)
  • Ideal starter set for cleaning and polishing including 20 accessories
26150687JA
1 piece
£19.00*
Multipurpose Set (687)
  • Set of accessories for cutting, carving, sanding, cleaning, polishing, grinding and sharpening
26150688JA
1 piece
£19.00*
Cutting Set (688)
  • Set of 68 cutting accessories to cut in a variety of materials
2615S723JA
1 piece
£35.00*
100 pieces DREMEL® Multipurpose Accessory Set (723)
  • Ideal Dremel starter kit with 100 accessories for various applications and materials
2615S724JA
1 piece
£48.00*
150 pieces DREMEL® Multipurpose Accessory Set (724)
  • Ideal Dremel starter kit with 150 accessories for a wide range of applications and materials
Dremel accesorry set SC725 in a plastic box with 70 accessories
Delivery details
  • Product box length, 4.5 cm
  • Product box height, 23 cm
  • Product box width, 19.5 cm
58 GBP
