Sanding
Dremel (504)
Smallest flap wheel (grit P80). Works well for (gentle) finish removal
£8.40*
RRP incl. VAT
What can you do with it?
Flap wheels are great for finish removal and light material clean up because they are more forgiving than sanding bands. They won’t bite into the material as quickly. They also tend to run a little cooler because of the flaps – so they are less likely to put any burn into the material. Grind and polish flat or contoured surfaces. Most effective when used as a finishing sander after heavier surface sanding and material removal is completed. Comes in fine and coarse grades
How to use?
Flap wheels are most effective when the edge is flat against the work piece, allowing for the most abrasion to take place.
Materials to use on and recommended speed
Aluminium 20-25.000
Brass 20-25.000
Copper 20-25.000
Hardwood 20-25.000
Plastic 20-25.000
Softwood 20-25.000
Steel 20-25.000
Brass 20-25.000
Copper 20-25.000
Hardwood 20-25.000
Plastic 20-25.000
Softwood 20-25.000
Steel 20-25.000
Example of usage
Technical details for Flap wheel 4,8 mm (504)
- Plywood
- Softwood
- Chipboard
- Hardwood
- Soft Metal
- Brass
- Hardened Steel
- Gold
- Aluminium
- Silver
- Stainless Steel
- Copper
- Rubber
- Plastic
- Plexiglass
- RPM
Technical specifications
Shank diameter
Working diameter
4,8 mm
Accessory length
50,0 mm
Cloth-Reinforced with Aluminum Oxide Abrasive
Shape
Wheel
Mandrel use
No Mandrel Needed
Grit
80
30,0 mm
Maximum RPM
30,0
Height
44,0
Suitable Dremel devices
Retired Products
Multi-Tools
2615050432
8710364015269
Delivery details: Flap wheel 4,8 mm (504)
Product box length, 2.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615050432
8710364015269
8710364015269
