Sanding
Flap wheel 9,5 mm (502)
Sanding
Largest flap wheel (grit P80). Works well for (gentle) finish removal
- Flapwheels grind and polish flat or contoured surfaces
- Effective as finishing sander after heavy -surface sanding and material removal is complete
- 80 grit for medium finish sanding
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
What can you do with it?
Flap wheels are great for finish removal and light material clean up because they are more forgiving than sanding bands. They won’t bite into the material as quickly. They also tend to run a little cooler because of the flaps – so they are less likely to put any burn into the material. Grind and polish flat or contoured surfaces. Most effective when used as a finishing sander after heavier surface sanding and material removal is completed. Comes in fine and coarse grades
How to use?
Flap wheels are most effective when the edge is flat against the work piece, allowing for the most abrasion to take place.
Materials to use on and recommended speed
Aluminium 30-35000 Brass 30-35000 Copper 30-35000 Hardwood 30000 Plastic 10000 Softwood 35000 Steel 35000
- Largest flap wheel (grit P80). Works well for (gentle) finish removal
DREMEL® EZ SpeedClic: Sanding Discs (SC411) 6 pieces
- Easy to change disks for flat and edge sanding of e.g. wood
Sanding Band 13 mm 60 grit (408) 6 pieces
- Large sanding band for sanding of wood and plastics
Flap wheel 4,8 mm (504)
- Smallest flap wheel (grit P80). Works well for (gentle) finish removal
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 2.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
