Cutting
Dremel (420)
Heavy Duty Cut-Off Wheel 24 mm
Heavy Duty Cut-Off Wheel 24 mm Heavy Duty Cut-Off Wheel 24 mm Heavy Duty Cut-Off Wheel 24 mm
For tougher cutting in metals, like hardened steel
£10.30* RRP incl. VAT
What can you do with it?
Good for slicing, making straight cuts and slots in all kinds of metal, like hardened steel, sheets metal or aluminum.
Easily cut bolts, or make slots in rusted and/or stripped bolts / screws for removal with a screwdriver.
How to use?
Use with 402 Mandrel: unscrew the top screw on the mandrel using the wrench, put the screw through the middle hole of the disk and screw it back on the mandrel.
If using the metal cutting wheels, cut on high speed – use light pressure. The wheels will last longer and cut faster if light pressure is used rather than heavy pressure and there is less risk of breaking it.
Since these disks are abrasive, the diameter of the wheel is going to wear away. If the wheel becomes too small to execute the cut, stop the cut and replace the wheel.
When using a cut-off wheel, we recommend using a two handed golf like grip to hold and guide the tool and go for a right angle. If you angle the wheel in the cut, the wheel will probably break.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron. But also for short cuts in plastic or brick.
On materials like a galvanized metal (Ductwork) or hardened steel, it’s best to use reinforced cut-off wheel (426)
Recommended speed
Aluminium 25-30.000 Brass 25-30.000 Copper 25-30.000 Plastic 10-25.000 Steel 25-30.000
Technical details for Heavy Duty Cut-Off Wheel 24 mm (420)
  • Glass fibre reinforced plastics Glass fibre reinforced plastics
  • Brick Brick
  • Marble Marble
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
  • Plastic Plastic
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
24,0 mm
Max working depth
10,0 mm
Rubber reinforced, Aluminum Oxide
Shape
Wheel
Mandrel use
Use with 402 Screw Mandrel
24,0 mm
Maximum RPM
24,0 mm
Height
1,0 mm
Variations
Delivery details: Heavy Duty Cut-Off Wheel 24 mm (420)
Product box length, 1 cm
Product box height, 10 cm
Product box width, 5 cm
2615042032
8710364007431
Recommended products:
Cutting Set
£19.00* RRP incl. VAT
