Carving / Engraving
High Speed Cutter 5,6 mm (196-2) 2 pieces
Carving / Engraving
Medium sized cylindrical shaped head. Shape of e.g. wood.
- Ideal for shaping, hollowing, grooving, slotting, inlaying, and making tapered holes
- The cylinder shape of the carving bit allows for deep removal of material, and makes stop cuts and v-cuts
- The accessory tip makes flat bottom slots and grooves, flat side cuts, and v-cuts when held at 45-degrees
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
What can you do with it?
High Speed Cutters work well for material removal in applications like shaping, carving, engraving, hollowing, grooving, slotting, inlaying making tapered holes or freehand routing. Tip: see the icon image or video for the result in the material.
How to use?
Use the sides of the head for an effective result. Most used grip for this accessory is the pencil grip. A less aggressive, more frequent pass will always produce better results than pushing too hard or forcing the tool through the material Use it at an angle less than 90' Advised Attachment: FLEXIBLE SHAFT (225); FLEX-SHAFT TOOL HOLDER (2222); DETAILER'S GRIP ATTACHMENT (577); MULTI-VISE (2500)
Materials to use on
This accessory works best on softer materials like wood, plastic and soft metals such as aluminum, copper, and brass. See the extensive List of materials in the images below
Recommended speed
Aluminium 15.000-25.000 Brass 15.000-25.000 Copper 15.000-25.000 Hardwood 20.000-30.000 Softwood 20.000-30.000 Plastic 15.000-20.000 Steel 15.000-25.000
- Medium sized cylindrical shaped head. Shape of e.g. wood.
High Speed Cutter 7,8 mm (114-2) 2 pieces
- Largest ball shaped head. Carve and engrave in e.g. wood
Carving bit DREMEL® MAX (115DM) 2 pieces
- Cylindrical-shaped Dremel Max carving bit for wood and more
High Speed Cutter 7,8 mm (115-2) 2 pieces
- Largest cylindrical shaped head. Carve and engrave in e.g. wood
Carving bit DREMEL® MAX (117DM) 2 pieces
- Curve-shaped Dremel Max carving bit for wood and more
High Speed Cutter 6,4 mm (117-2) 2 pieces
- Carve and engrave in curved and straigh material like wood
High Speed Cutter 3,2 mm (118-2) 2 pieces
- Smallest triangular shaped head. Shape and create V-grooves in e.g. wood.
High Speed Cutter 6,4 mm (125-2) 2 pieces
- Largest triangular shaped head. Shape and create V-grooves in e.g. wood.
High Speed Cutter 7,2 mm (134-2) 2 pieces
- Carve and remove a lot of material like wood
High Speed Cutter 7,8 mm (144-2) 2 pieces
High Speed Cutter 4,8 mm (192-2) 2 pieces
- Medium sized ball shaped head. Carve and engrave in e.g. wood
High Speed Cutter 2,0 mm (193-2) 2 pieces
- Medium sized cylindrical shaped head. Detailed shaping of e.g. wood.
Engraving Bit DREMEL® MAX (194DM) 2 pieces
High Speed Cutter 3,2 mm (194-2) 2 pieces
High Speed Cutter 9,5 mm (199-2) 2 pieces
- Create small grooves and detailed cuts in e.g. wood
Suitable Dremel devices
Retired Products
Multi-Tools
- 2 pcs
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
