Carving / Engraving
Dremel (144)
High Speed Cutter 7,8 mm
High Speed Cutter 7,8 mm High Speed Cutter 7,8 mm High Speed Cutter 7,8 mm
Carve and remove a lot of material like wood
£15.00* RRP incl. VAT
What can you do with it?
High Speed Cutters work well for material removal in applications like shaping, carving, engraving, hollowing, grooving, slotting, inlaying making tapered holes or freehand routing. Tip: see the icon image or video for the result in the material.
How to use?
Use the sides of the head for an effective result.
Most used grip for this accessory is the pencil grip.
A less aggressive, more frequent pass will always produce better results than pushing too hard or forcing the tool through the material
Use it at an angle less than 90'
Advised Attachment: FLEXIBLE SHAFT (225); FLEX-SHAFT TOOL HOLDER (2222); DETAILER'S GRIP ATTACHMENT (577); MULTI-VISE (2500)
Materials to use on
This accessory works best on softer materials like wood, plastic and soft metals such as aluminum, copper, and brass. See the extensive List of materials in the images below
Recommended speed
Aluminium 15-25.000
Brass 15-25.000
Copper 15-25.000
Hardwood 20-30.000
Softwood 20-30.000
Plastic 15-20.000
Steel 15-25.000
Technical details for High Speed Cutter 7,8 mm (144)
  • Veneered woods Veneered woods
  • Softwood Softwood
  • Leather Leather
  • Plywood Plywood
  • Laminates Laminates
  • Chipboard Chipboard
  • Brick Brick
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Carbon Carbon
Technical specifications
Shank diameter
Working diameter
7,8 mm
Accessory length
High Speed Steel
Shape
Pear
Mandrel use
No Mandrel Needed
8,0 mm
8,0 mm
Height
Maximum RPM
30.000 1/min
Variations
Delivery details: High Speed Cutter 7,8 mm (144)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1 cm
26150144JA
8710364044726
Recommended products:
Multipurpose Set
£19.00* RRP incl. VAT
