Carving / Engraving
High Speed Cutter 7,8 mm (115) 2 pieces
Carving / Engraving
Largest cylindrical shaped head. Carve and engrave in e.g. wood
  • Ideal for shaping, hollowing, grooving, slotting, inlaying, and making tapered holes
  • The cylinder shape of the carving bit allows for deep removal of material, and makes stop cuts and v-cuts
  • The accessory tip makes flat bottom slots and grooves, flat side cuts, and v-cuts when held at 45-degrees
See all variations
16.5 GBP
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
What can you do with it?
High Speed Cutters work well for material removal in applications like shaping, carving, engraving, hollowing, grooving, slotting, inlaying making tapered holes or freehand routing. Tip: see the icon image or video for the result in the material.
How to use?
Use the sides of the head for an effective result. Most used grip for this accessory is the pencil grip. A less aggressive, more frequent pass will always produce better results than pushing too hard or forcing the tool through the material Use it at an angle less than 90' Advised Attachment: FLEXIBLE SHAFT (225); FLEX-SHAFT TOOL HOLDER (2222); DETAILER'S GRIP ATTACHMENT (577); MULTI-VISE (2500)
Materials to use on
This accessory works best on softer materials like wood, plastic and soft metals such as aluminum, copper, and brass. See the extensive List of materials in the images below
Recommended speed
Aluminium 30.000 Brass 30.000 Copper 30.000 Hardwood 35.000 Softwood 20-25.000 Plastic 35.000 Steel 20-25.000
Shank diameter
Working diameter
Accessory length
Package contents
Price
26150115JA
7,8 mm
2 pieces
£16.50*
  • Largest cylindrical shaped head. Carve and engrave in e.g. wood
26150196JA
5,6 mm
2 pieces
£12.50*
High Speed Cutter 5,6 mm (196) 2 pieces
  • Medium sized cylindrical shaped head. Shape of e.g. wood.
26150194JA
2 pieces
£10.50*
High Speed Cutter 3,2 mm (194) 2 pieces
26150144JA
7,8 mm
2 pieces
£16.50*
High Speed Cutter 7,8 mm (144) 2 pieces
  • Carve and remove a lot of material like wood
26150125JA
2 pieces
£13.00*
High Speed Cutter 6,4 mm (125) 2 pieces
  • Largest triangular shaped head. Shape and create V-grooves in e.g. wood.
26150134JA
7,2 mm
2 pieces
£16.50*
High Speed Cutter 7,2 mm (134) 2 pieces
26150114JA
7,8 mm
2 pieces
£16.00*
High Speed Cutter 7,8 mm (114) 2 pieces
  • Largest ball shaped head. Carve and engrave in e.g. wood
26150117JA
2 pieces
£13.50*
High Speed Cutter 6,4 mm (117) 2 pieces
  • Carve and engrave in curved and straigh material like wood
Shank diameter
Working diameter
7,8 mm
Accessory length
High Speed Steel
Shape
Cylinder
Mandrel use
No Mandrel Needed
8,0 mm
8,0 mm
Height
Maximum RPM
30.000 1/min
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044641
26150115JA
Dremel accessory 115_High Speed Cutter 7,8 mm
Delivery details
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 2.5 cm
16.5 GBP
