Carving / Engraving
High Speed Cutter 9,5 mm (199-2) 2 pieces
Carving / Engraving
Create small grooves and detailed cuts in e.g. wood
  • Ideal for shaping, hollowing, grooving and making tapered holes especially on curved surfaces
  • Perfect for slotting and inletting
  • For use on soft metals, plastic, wood and other soft materials
See all variations
21.5 GBP
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
What can you do with it?
High Speed Cutters work well for material removal in applications like shaping, carving, engraving, hollowing, grooving, slotting, inlaying making tapered holes or freehand routing. Tip: see the icon image or video for the result in the material.
How to use?
Use the sides of the head for an effective result. Most used grip for this accessory is the pencil grip. A less aggressive, more frequent pass will always produce better results than pushing too hard or forcing the tool through the material Use it at an angle less than 90' Advised Attachment: FLEXIBLE SHAFT (225); FLEX-SHAFT TOOL HOLDER (2222); DETAILER'S GRIP ATTACHMENT (577); MULTI-VISE (2500)
Materials to use on
This accessory works best on softer materials like wood, plastic and soft metals such as aluminum, copper, and brass. See the extensive List of materials in the images below
Recommended speed
Aluminium 15.000-20.000 Brass 15.000-20.000 Copper 15.000-20.000 Hardwood 20.000-30.000 Softwood 20.000-30.000 Plastic 15.000-20.000 Steel 15.000-25.000
Shank diameter
Working diameter
Accessory length
Package contents
Price
26150199JA
9.5 mm
39.0 mm
2 pieces
£21.00*
  • Create small grooves and detailed cuts in e.g. wood
26150114JA
7.8 mm
38.0 mm
2 pieces
£16.00*
High Speed Cutter 7,8 mm (114-2) 2 pieces
  • Largest ball shaped head. Carve and engrave in e.g. wood
26150115DM
7.8 mm
38.0 mm
2 pieces
£22.50*
Carving bit DREMEL® MAX (115DM) 2 pieces
  • Cylindrical-shaped Dremel Max carving bit for wood and more
26150115JA
7.8 mm
38.0 mm
2 pieces
£16.50*
High Speed Cutter 7,8 mm (115-2) 2 pieces
  • Largest cylindrical shaped head. Carve and engrave in e.g. wood
26150117DM
6.4 mm
38.0 mm
2 pieces
£26.50*
Carving bit DREMEL® MAX (117DM) 2 pieces
  • Curve-shaped Dremel Max carving bit for wood and more
26150117JA
6.4 mm
38.0 mm
2 pieces
£13.50*
High Speed Cutter 6,4 mm (117-2) 2 pieces
  • Carve and engrave in curved and straigh material like wood
26150118JA
3.2 mm
38.0 mm
2 pieces
£11.00*
High Speed Cutter 3,2 mm (118-2) 2 pieces
  • Smallest triangular shaped head. Shape and create V-grooves in e.g. wood.
26150125JA
6.4 mm
38.0 mm
2 pieces
£13.00*
High Speed Cutter 6,4 mm (125-2) 2 pieces
  • Largest triangular shaped head. Shape and create V-grooves in e.g. wood.
26150134JA
7.2 mm
39.0 mm
2 pieces
£16.50*
High Speed Cutter 7,2 mm (134-2) 2 pieces
  • Carve and remove a lot of material like wood
26150144JA
7.8 mm
39.0 mm
2 pieces
£16.50*
High Speed Cutter 7,8 mm (144-2) 2 pieces
26150192JA
4.8 mm
39.0 mm
2 pieces
£13.50*
High Speed Cutter 4,8 mm (192-2) 2 pieces
  • Medium sized ball shaped head. Carve and engrave in e.g. wood
26150193JA
2.0 mm
39.0 mm
2 pieces
£10.50*
High Speed Cutter 2,0 mm (193-2) 2 pieces
  • Medium sized cylindrical shaped head. Detailed shaping of e.g. wood.
26150194DM
3.2 mm
39.0 mm
2 pieces
£14.00*
Engraving Bit DREMEL® MAX (194DM) 2 pieces
26150194JA
3.2 mm
39.0 mm
2 pieces
£10.50*
High Speed Cutter 3,2 mm (194-2) 2 pieces
  • Medium sized cylindrical shaped head. Shape of e.g. wood.
26150196JA
5.6 mm
39.0 mm
2 pieces
£12.50*
High Speed Cutter 5,6 mm (196-2) 2 pieces
Shank diameter
Working diameter
9.5 mm
Accessory length
39.0 mm
High Speed Steel
Shape
Disc
Mandrel use
No Mandrel Needed
10.0 mm
10.0 mm
Height
39.0 mm
Maximum RPM
30,000 1/min
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044757
26150199JA
2  pieces High Speed Cutter 9,5 mm to create small grooves and detailed cuts in  wood
Delivery details
  • 2 pcs
  • Product box length, 5 cm
  • Product box height, 10 cm
  • Product box width, 2.5 cm
21.5 GBP
