Cleaning / Polishing
Impregnated Polishing Wheel (520)
With pre-applied polishing compound. Best for light stock removal on metals
  • Designed for light stock removal and high luster polishing
  • Works on a variety of surfaces including steel, aluminum, brass, silver, hard plastics, gold and other metals
  • Impregnated with silicone abrasive and lubricant
6.4 GBP
Metal pipes
Sheet Metal
Cast iron
Soft Metal
Ceramic
Granite
Marble
Plastic
Copper
Gold
Silver
Stainless Steel
Hardened Steel
Shank diameter
Working diameter
13.2 mm
Accessory length
54.0 mm
Felt Fabric with Silicon Carbide Abrasive
Shape
Wheel
Mandrel use
No Mandrel Needed
13.0 mm
Maximum RPM
20,000 1/min
13.0 mm
Height
54.0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364023035
2615052065
Dremel accessory  520_Impregnated Polishing Wheel
Delivery details
  • 1 pc
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
6.4 GBP
