Collets / Mandrels / Miscellaneous
Mandrel (402-4) 4 pieces
Mandrel to mount different accessories to use with your Dremel Multi-Tool
- The 402 mandrel is used primarily with Dremel Cut-off Wheels and Polishing Wheels
- Features a slotted screw head and a 3.2 mm shank
- For use in all Dremel Multi-Tools
Mount cutting discs and different cleaning and polishing accessories. The 402 mandrel is used with the following Dremel accessories: 409, 411, 412, 413, 420, 423, 425, 426, 456, 511, 512, 540 and 541. Features a slotted screw head and a 3.2 mm shank for use with all Dremel Multi-Tools. Use the flathead wrench to loosen or tighten the mandrels screw.
- Mandrel to mount different accessories to use with your Dremel Multi-Tool
Mandrel (401-3) 3 pieces
- Mandrel tomount different cleaning and polishing accessories
EZ SpeedClic Mandrel (SC402)
Collets (3,2 mm) including a collet nut (4485)
- Improve the grip for bits in our Multi-Tool line
Multi Chuck (0.8-3.2 mm) (4486)
- Provides quick and easy tool-free accessory changes
Suitable Dremel devices
Retired Products
Multi-Tools
- 4 pcs
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
