Collets / Mandrels / Miscellaneous
Multi Chuck (0.8-3.2 mm) (4486)
Bestseller
Bestseller
Provides quick and easy tool-free accessory changes
  • Eliminate the collet and wrench when changing Dremel accessories
  • Accepts all accessory bits with 0.8 - 3.2 mm shanks
  • Can be used with the Flexible Shaft attachment (225) and Right Angle attachment (575)
16.5 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Now have wrench-free accessory changes. The keyless chuck holds accessories without using a collet and eliminates having to use a wrench for quick and easy accessory changes. Ideal when the application requires numerous accessory changes. Accepts all accessory bits with 0.8 - 3.2 mm shanks.
Shape
Chuck
Mandrel use
No Mandrel Needed
Usage
To change accessories quickly and easily without collets.
15.0 mm
Maximum RPM
35,000 1/min
15.0 mm
Height
22.0 mm
Suitable Dremel devices
Retired Products
Multi-Tools
8710364012978
2615448632
Dremel  Multi chuck
Delivery details
  • 1x Dremel 8826 Multi-Chuck (0.8-3.2 mm)
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
16.5 GBP
