Collets/Mandrels/Miscellaneous
Multi Chuck (0.8-3.2 mm) (4486)
Provides quick and easy tool-free accessory changes
Eliminate the collet and wrench when changing Dremel accessories
Accepts all accessory bits with 0.8 - 3.2 mm shanks
Can be used with the Flexible Shaft attachment (225) and Right Angle attachment (575)
1x Dremel Multi-Chuck
£13.00*
RRP incl. VAT
Now have wrench-free accessory changes. The keyless chuck holds accessories without using a collet and eliminates having to use a wrench for quick and easy accessory changes. Ideal when the application requires numerous accessory changes. Accepts all accessory bits with 0.8 - 3.2 mm shanks.
Technical details for Multi Chuck (0.8-3.2 mm) (4486)
Technical specifications
Usage
To change accessories quickly and easily without collets.
15,0 mm
Maximum RPM
15,0 mm
Height
22,0 mm
Package Contents
1 piece
Suitable Dremel devices
Multi-Tools
2615448632
8710364012978
Similar Accessories (4)
Delivery details: Multi Chuck (0.8-3.2 mm) (4486)
1x Dremel 8826 Multi-Chuck (0.8-3.2 mm)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
2615448632
8710364012978
8710364012978
