Cleaning / Polishing
Polishing Wheel 13 mm (414) 6 pieces
Smallest cylindrical shaped polishing wheel. Ideal for detailed polishing metals and plastics.
- Ideal for general polishing
- Use on most ferrous metals, stones, glass and ceramics
- Can be used with 421 polishing compound to produce a smooth finish
See all variations
3.2 GBP
Glass fibre reinforced plastics
Steel profiles
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Plastic
Plexiglass
Working diameter
Maximum RPM
Package contents
Price
2615041432
13.0 mm
20,000 1/min
6 pieces
£3.10*
- Smallest cylindrical shaped polishing wheel. Ideal for detailed polishing metals and plastics.
Order number2615041432
EAN-Code8710364007141
2615S423JA
25.0 mm
20,000 1/min
1 piece
£4.10*
DREMEL® EZ SpeedClic: Polishing Cloth Wheel. (423S)
- Polish silverware to high luster and for car detailing
Order number2615S423JA
EAN-Code8710364037124
26150429JA
26.0 mm
20,000 1/min
3 pieces
£6.30*
Polishing Wheel 26 mm (429-3) 3 pieces
- Biggest Cylindrical shaped wheel. For polishing metals and plastics.
Order number26150429JA
EAN-Code8710364045044
26150422JA
10.0 mm
20,000 1/min
4 pieces
£8.20*
Polishing point 10 mm (422-4) 4 pieces
- For polishing metals and plastics on flat surfaces or holes
Order number26150422JA
EAN-Code8710364045051
Shank diameter
Working diameter
13.0 mm
Felt Fabric
Shape
Wheel
Mandrel use
Use with 401 Thread Mandrel
12.0 mm
Maximum RPM
20,000 1/min
12.0 mm
Height
6.0 mm
6
6
Suitable Dremel devices
Retired Products
Multi-Tools
8710364007141
2615041432
EAN Code8710364007141
Delivery details- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
3.2 GBP
