Cleaning / Polishing
Polishing Wheel 22,5 mm (425-4) 4 pieces
For removing scratch marks on non-ferrous materials like stone and glass
  • Ideal for general polishing of most ferrous metals, stones, glass and ceramics
  • Use it to remove small burrs and scratch marks left by grinding and sanding
  • Ideal to clean and define grooves
See all variations
7 GBP
Glass fibre reinforced plastics
Steel profiles
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Plastic
Plexiglass
Working diameter
Maximum RPM
Package contents
Price
26150425JA
22.5 mm
20,000 1/min
4 pieces
£6.90*
  • For removing scratch marks on non-ferrous materials like stone and glass
2615041432
13.0 mm
20,000 1/min
6 pieces
£3.10*
Polishing Wheel 13 mm (414) 6 pieces
  • Smallest cylindrical shaped polishing wheel. Ideal for detailed polishing metals and plastics.
2615042132
20,000 1/min
1 piece
£3.60*
Polishing Compound (421)
  • Apply to polishing wheels for dull oxidized film and imperfections on metals and plastics.
26150422JA
10.0 mm
20,000 1/min
4 pieces
£8.20*
Polishing point 10 mm (422-4) 4 pieces
  • For polishing metals and plastics on flat surfaces or holes
26150425JA
22.5 mm
20,000 1/min
4 pieces
£6.90*
26150429JA
26.0 mm
20,000 1/min
3 pieces
£6.30*
Polishing Wheel 26 mm (429-3) 3 pieces
  • Biggest Cylindrical shaped wheel. For polishing metals and plastics.
Shank diameter
Working diameter
22.5 mm
Synthetic Rubber Abrasive
Shape
Wheel
Mandrel use
Use with 402 Screw Mandrel
22.0 mm
Maximum RPM
20,000 1/min
22.0 mm
Height
4.0 mm
4
4
Suitable Dremel devices
Retired Products
Multi-Tools
8710364045075
26150425JA
Four gray circular abrasive cutting wheels with center holes aligned in a row on a white background.
Delivery details
  • 4 pcs
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
7 GBP
