Drilling
Precision Drill Bit Set (628) 7 pieces
Drilling
Set of drill bits for precise drilling
- Set of 7 drill bits made from high-grade steel for precise drilling.
- Ideal for drilling into soft metals, wood, plexiglass and plastic.
- Stored in a convenient storage box.
Plexiglass
Plastic
Soft Metal
Softwood
Hardwood
What can you do with it?
This set contains 7 multipurpose drill bits for precise drilling in a variety of materials with your Dremel Multi-Tool. Easily drill clean and smooth holes into soft metal, plexiglass, plastic or wood. The durable and qualitative drill bits are made from high-grade steel and are stored in a convenient storage box.
How to use?
Pick the right size for your project. Use the tip of the drill bit to go into the material straight at a 90° angle. Use the bits with the smallest shank size with the Multi-Chuck (4486). Advised attachments: Detailer's Grip (577)
Materials to use on
Hard wood; plastic; plexiglass; soft metal; soft wood.
Recommended speed
Soft Wood 20- 30.000 Hard Wood 20- 30.000 Laminates / Plastics 10-15.000 Steel 20-30.000 Aluminum / Brass 20- 30.000
- Set of drill bits for precise drilling
DREMEL® MAX Precision Drill Bit set (628DM) 7 pieces
- 7-piece highly durable drill bit set in various sizes.
Suitable Dremel devices
Retired Products
Multi-Tools
- 1x 0.8mm Drill bit 1x 1.2 Drill bit 1x 1.6mm Drill bit 1x 2.0mm Drill bit 1x 2.4mm Drill bit 1x 2.8mm Drill bit 1x 3.2mm Drill bit
- Product box length, 1.5 cm
- Product box height, 13.5 cm
- Product box width, 6.7 cm
