Cutting
Rip/Cross-Cut Blade 31,8 mm (546-2) 2 pieces
Cutting
Long-lasting, mini circular blade that cuts both with and across the grain on wood and wood-like materials
- The 31.8 mm wheel mounts directly to the 670 Mini Saw attachment without the need of a mandrel
- Made with steel and has 48 cutting teeth for optimal cutting performance
- Designed to be used only in conjunction with the Dremel 670 Mini Saw attachment
Sandwich material
Veneered woods
Softwood
Hardwood
Plywood
Laminates
Chipboard
Fiberboard
What can you do with it?
Precision saw blade for fine, clean and straight cuts in all sorts of wood. Perfect for laminate and wood flooring or thin wood plates. Made of carbon steel with 48 offset teeth to guarantee precise, fast cuts up to 6.35 mm.
How to use?
Use only with Dremel Mini Saw attachment 670. The 31.8 mm diameter steel blade mounts directly to the 670 Mini Saw attachment without the need of a mandrel. Fits with all Dremel Multi-Tools or other 3,2mm shank size Multi-Tools.
Materials to use on
Suitable for use on wood and wood-like materials (softwood, hardwood, manufactured wood).
Recommended Speed
20.000-30.000 RPM
Suitable Dremel devices
Retired Products
Multi-Tools
- 2 pcs
- Product box length, 1.5 cm
- Product box height, 10 cm
- Product box width, 5 cm
