Cutting
Rip/Cross-Cut Blade 31,8 mm (546)
Rip/Cross-Cut Blade 31,8 mm Rip/Cross-Cut Blade 31,8 mm
Long-lasting, mini circular blade that cuts both with and across the grain on wood and wood-like materials
  • The 31.8 mm wheel mounts directly to the 670 Mini Saw attachment without the need of a mandrel
  • Made with steel and has 48 cutting teeth for optimal cutting performance
  • Designed to be used only in conjunction with the Dremel 670 Mini Saw attachment
£10.00* RRP incl. VAT
What can you do with it?
Precision saw blade for fine, clean and straight cuts in all sorts of wood. Perfect for laminate and wood flooring or thin wood plates. Made of carbon steel with 48 offset teeth to guarantee precise, fast cuts up to 6.35 mm.
How to use?
Use only with Dremel Mini Saw attachment 670. The 31.8 mm diameter steel blade mounts directly to the 670 Mini Saw attachment without the need of a mandrel.
Example of usage
Technical details for Rip/Cross-Cut Blade 31,8 mm (546)
  • Sandwich material Sandwich material
  • Veneered woods Veneered woods
  • Softwood Softwood
  • Hardwood Hardwood
  • Plywood Plywood
  • Laminates Laminates
  • Chipboard Chipboard
  • Fiberboard Fiberboard
  • Attachment Attachment
Technical specifications
Shank diameter
Working diameter
31,8 mm
Max working depth
Usage
Precision saw blade for fine, clean and straight cuts in all sorts of wood. Perfect for laminate and wood flooring or thin wood plates. Use only with Dremel Mini Saw attachment 670. Made of carbon steel, 48 offset teeth guarantee precise, fast cuts up to 6.35 mm.
32,0 mm
Maximum RPM
32,0 mm
Height
1,0 mm
Package Contents
2 pieces
Variations
Delivery details: Rip/Cross-Cut Blade 31,8 mm (546)
1x Rip/Cross-Cut Blade 31.8 mm
Product box length, 1.5 cm
Product box height, 10 cm
Product box width, 5 cm
26150546JB
8710364045143
Recommended products:
DREMEL® Mini Saw Attachment
£35.00* RRP incl. VAT
