Routing
Router Bit (HSS) 4,8 mm (652)
Routing
Second to smallest straight edge router bit. For routing in wood
- Used for edging and grooving wood, Dremel router bits are ideal for routing, inlaying and mortising in wood and other soft materials
- Straight router bits are flat on the bottom for cutting square grooves, rabbets, and dadoes, as well as leveling recessed areas
- High-quality router bit included
See all variations
11 GBP
Veneered woods
Fiberboard
Chipboard
Laminates
Plywood
Softwood
Hardwood
Rubber
Plastic
Plexiglass
Carbon
Straight Bits.
General purpose routing or grooving.
Shank diameter
Working diameter
Accessory length
Package contents
Price
2615065232
4,8 mm
36,0 mm
1 piece
£11.00*
- Second to smallest straight edge router bit. For routing in wood
Order number2615065232
EAN-Code8710364008315
26150655JA
8,0 mm
37,0 mm
1 piece
£22.00*
- Biggest straight edge router bit. For routing in wood
Order number26150655JA
EAN-Code8710364023042
2615065032
36,0 mm
1 piece
£11.00*
- Smallest straight edge router bit. For routing in wood
Order number2615065032
EAN-Code8710364007417
2615065432
36,0 mm
1 piece
£11.00*
- Second to biggest straight edge router bit. For routing in wood
Order number2615065432
EAN-Code8710364008322
Shank diameter
Working diameter
4,8 mm
Working length
1,4 mm
Accessory length
36,0 mm
High Speed Steel
Mandrel use
No Mandrel Needed
Usage
Straight
4,0 mm
4,0 mm
Height
36,0 mm
Maximum RPM
Suitable Dremel devices
Retired Products
Multi-Tools
8710364008315
2615065232
EAN Code8710364008315
Delivery details- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
11 GBP
