Routing
Dremel (652)
Router Bit (HSS) 4,8 mm
Router Bit (HSS) 4,8 mm Router Bit (HSS) 4,8 mm
Second to smallest straight edge router bit. For routing in wood
£10.00* RRP incl. VAT
Straight Bits.
General purpose routing or grooving.
Example of usage
Technical details for Router Bit (HSS) 4,8 mm (652)
  • Veneered woods Veneered woods
  • Fiberboard Fiberboard
  • Chipboard Chipboard
  • Laminates Laminates
  • Plywood Plywood
  • Softwood Softwood
  • Hardwood Hardwood
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Carbon Carbon
  • Attachment Attachment
Technical specifications
Shank diameter
Working diameter
4,8 mm
Working length
1,4 mm
Accessory length
36,0 mm
High Speed Steel
Mandrel use
No Mandrel Needed
Usage
Straight
4,0 mm
4,0 mm
Height
36,0 mm
Maximum RPM
Variations
Delivery details: Router Bit (HSS) 4,8 mm (652)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615065232
8710364008315
