Routing
Router Bit (HSS) 6,4 mm (640)
Routing
For inlaying and routing a V groove in wood
- Used for edging and grooving wood, Dremel router bits are ideal for routing, inlaying and mortising in wood and other soft materials
- V-groove router bits are used for cutting chamfered edges and for various types of decorative carving
- High-quality router bit
See all variations
11.2 GBP
Veneered woods
Fiberboard
Chipboard
Laminates
Plywood
Softwood
Hardwood
Rubber
Plastic
Plexiglass
Carbon
V-Groove Bit.
For sign word and lettering.
Shank diameter
Working diameter
Accessory length
Package contents
Price
2615064032
6.4 mm
37.0 mm
1 piece
£11.00*
- For inlaying and routing a V groove in wood
Order number2615064032
EAN-Code8710364008308
2615061232
9.5 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (612)
- For making a round edge to your wooden workpiece
Order number2615061232
EAN-Code8710364008254
2615061532
9.5 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 9,5 mm (615)
Order number2615061532
EAN-Code8710364008285
2615065032
3.2 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 3,2 mm (650)
- Smallest straight edge router bit. For routing in wood
Order number2615065032
EAN-Code8710364007417
2615065232
4.8 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 4,8 mm (652)
- Second to smallest straight edge router bit. For routing in wood
Order number2615065232
EAN-Code8710364008315
2615065432
6.4 mm
36.0 mm
1 piece
£11.00*
Router Bit (HSS) 6,4 mm (654)
- Second to biggest straight edge router bit. For routing in wood
Order number2615065432
EAN-Code8710364008322
26150655JA
8.0 mm
37.0 mm
1 piece
£22.00*
Router Bit (HSS) 8,0 mm (655)
- Biggest straight edge router bit. For routing in wood
Order number26150655JA
EAN-Code8710364023042
26150660JA
1 piece
£46.00*
DREMEL® Multipurpose Router Bit Set (660)
- Set of 7 routing accessories to rout in a variety of materials
Order number26150660JA
EAN-Code8710364069972
Shank diameter
Working diameter
6.4 mm
Working length
2.0 mm
Accessory length
37.0 mm
High Speed Steel
Mandrel use
No Mandrel Needed
Usage
V-Groove
4.0 mm
6.0 mm
Height
36.0 mm
Maximum RPM
35,000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364008308
2615064032
EAN Code8710364008308
Delivery details- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
11.2 GBP
