Sanding
Sanding Band 13 mm 120 grit (432) 6 pieces
Sanding
Large sanding band for sanding of wood and plastics
- For shaping and smoothing wood and fiberglass
- Removes rust from metal surfaces
- Shapes rubber surfaces
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S or 511E/512E.
How to use?
Change 13mm sanding bands 5X faster with the EZ SpeedClic Sanding Drum Mandrel (SC407) than a standard mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 10-35000 Softwood 10-35000 Aluminium 35000 Brass 35000 Ceramic 10-35000 Copper 25-35000 Plastic 10-20000 Stone 10-35000 Shell 10-35000 Steel 35000
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.8 cm
- Product box height, 10 cm
- Product box width, 5 cm
