Sanding
Sanding Band 13 mm 60 grit (408) 6 pieces
Bestseller
Sanding
Bestseller
Large sanding band for sanding of wood and plastics
  • Ideal for shaping and smoothing
  • Removes rust from metal surfaces
  • Designed for use on wood and fiberglass
See all variations
3.3 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S or 511E/512E.
How to use?
Change 13mm sanding bands 5X faster with the EZ SpeedClic Sanding Drum Mandrel (SC407) than a standard mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE. The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Use the sides of the bands to do the sanding.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 10-35000 Softwood 10-35000 Aluminium 35000 Brass 35000 Ceramic 10-35000 Copper 25-35000 Plastic 10-20000 Stone 10-35000 Shell 10-35000 Steel 35000
Shank diameter
Working diameter
Grit
Package contents
Price
2615040832
3.2 mm
13.0 mm
6 pieces
£3.20*
  • Large sanding band for sanding of wood and plastics
2615040732
3.2 mm
13.0 mm
1 piece
£3.70*
Sanding Band & Mandrel 13 mm grit 60 (407)
  • For (painted) material removal / shaping of wood and plastics.
26150408DM
3.2 mm
13.0 mm
1 piece
£21.50*
Sanding band and hole drill DREMEL® MAX (408DM)
  • Sanding hard & soft woods, composites, fiberglass, Masonite boards, rigid foam, and more. Drilling soft wood and ceramic wall tile.
26150430JA
3.2 mm
6.4 mm
2 pieces
£8.00*
Sanding Band & Mandrel 6,4 mm 60 grit (430-2) 2 pieces
  • Small sanding mandrel and sanding band (Grit P60)
2615043132
3.2 mm
6.4 mm
6 pieces
£3.20*
Sanding Band 6,4 mm 60 grit (431) 6 pieces
  • Small sanding band for detailed sanding of wood and plastics
2615043232
3.2 mm
13.0 mm
6 pieces
£3.20*
Sanding Band 13 mm 120 grit (432) 6 pieces
2615043832
3.2 mm
6.4 mm
6 pieces
£3.20*
Sanding Band 6,4 mm 120 grit (438) 6 pieces
26150770JA
3.2 mm
6.4 mm
1 piece
£22.00*
DREMEL® 770B-02 (770B-02)
  • Versatile sanding band kit for shaping, smoothing, and rust removal.
26150771JA
3.2 mm
13.0 mm
1 piece
£22.00*
Sanding Band Variety Kit 13mm (771B02)
  • Comprehensive sanding band set for shaping, smoothing, and surface prep.
Shank diameter
3.2 mm
Working diameter
13.0 mm
Aluminum Oxide
Shape
Band
Mandrel use
Use with either Dremel EZ407SA/SC407 or 407 mandrels
Grit
60
15.0 mm
Maximum RPM
35,000 1/min
15.0
Height
13.0
6
6
Suitable Dremel devices
Retired Products
Multi-Tools
8710364007233
2615040832
Dremel accessory 408_Sanding Band 13 mm 60 grit
Delivery details
  • Product box length, 1.8 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
3.3 GBP
