Sanding
Sanding Band 6,4 mm 60 grit (431) 6 pieces
Sanding
Small sanding band for detailed sanding of wood and plastics
- A cylinder covered with aluminum oxide abrasive that sits atop a mandrel
- For rough shaping and smoothing wood and fiberglass
- Great for removing rust from metal surfaces
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S or 511E/512.
How to use?
The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Use the sides of the bands to do the sanding.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel. Can shape rubber surfaces
Recommended speed
Hardwood 15-25.000 Softwood 15-25.000 Aluminium 15-25.000 Brass 15-25.000 Ceramic 15-25.000 Copper 15-25.000 Plastic 15-25.000 Stone 15-25.000 Shell 15-25.000 Steel 15-25.000
- Small sanding band for detailed sanding of wood and plastics
Sanding Band & Mandrel 13 mm grit 60 (407)
- For (painted) material removal / shaping of wood and plastics.
Sanding Band 13 mm 60 grit (408) 6 pieces
- Large sanding band for sanding of wood and plastics
Sanding band and hole drill DREMEL® MAX (408DM)
- Sanding hard & soft woods, composites, fiberglass, Masonite boards, rigid foam, and more. Drilling soft wood and ceramic wall tile.
Sanding Band & Mandrel 6,4 mm 60 grit (430-2) 2 pieces
- Small sanding mandrel and sanding band (Grit P60)
Sanding Band 13 mm 120 grit (432) 6 pieces
Sanding Band 6,4 mm 120 grit (438) 6 pieces
DREMEL® 770B-02 (770B-02)
- Versatile sanding band kit for shaping, smoothing, and rust removal.
Sanding Band Variety Kit 13mm (771B02)
- Comprehensive sanding band set for shaping, smoothing, and surface prep.
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.8 cm
- Product box height, 10 cm
- Product box width, 5 cm
