Sanding
Sanding band and hole drill DREMEL® MAX (408DM)
Sanding
Sanding hard & soft woods, composites, fiberglass, Masonite boards, rigid foam, and more. Drilling soft wood and ceramic wall tile.
  • 30 times longer life compared to standard Dremel sanding band (408).
  • Carbide coating provides added durability to the surface of the drum and will not tear loose like other ordinary sanding bands.
  • Functions as both a sanding drum and a hole drill capable of plunge cutting into a variety of materials.
See all variations
22 GBP
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
Sanding- What can you do with it?
Mounted on an extra strong, steel mandrel the sanding drum allows you to move laterally or orbitally to smooth out surfaces, enlarge holes, or create irregular cavities.
How to use?
Drum is most effective when the edge is flat against the work piece. To find optimal speed, start slowly and gradually increase speed in order to avoid excessive heat. Let the tool do the work with reduced speed and apply little to no pressure in order to maximize accessory life. Not recommended for usage with metal or substances such as paint & other finishes as drum will be clogged easily.
Materials to use on
Ideal for a variety of materials including Hard and soft woods Ceramic wall tile Composites Plastic Fiberglass Stone Not recommended for use on metal
Sanding Recommended speed
Soft & Hard Wood 15000 - 35000 RPM Laminates/Plastics 15000 RPM Shell/Stone 25000 – 35000 RPM Ceramic 15000 RPM
Hole Drill - What can you do with it?
This accessory functions as both a sanding drum and a hole drill. With hole drill function you can plunge cut into a variety of materials.
How to use?
Start drilling by holding your tool on a 45 degree angle. Continue cutting, moving the tool in circular motion. Allow the tool to cut the whole gradually. This way you will build minimum heat around the accessory and maximize the accessory life. When drilling holes through ceramic wall tile, start hole on the non-glazed side of the tile. To remove a material plug stuck in the hole saw, fasten a screw into the plug and pull it out or lightly tap the plug with a punch until it breaks.
Materials to use on
Ideal for soft woods and ceramic wall tile. Not recommended for stone, porcelain, or hard floor tiles.
Hole drill - Recommended speed
Soft & Hard Wood 20000 RPM Laminates/Plastics 15000 RPM Ceramic 15000 – 20000 RPM
Shank diameter
Working diameter
GRIT
Package contents
Price
26150408DM
3.2 mm
13.0 mm
1 piece
£21.50*
  • Sanding hard & soft woods, composites, fiberglass, Masonite boards, rigid foam, and more. Drilling soft wood and ceramic wall tile.
2615S544JB
38.0 mm
1 piece
£26.50*
DREMEL® EZ SpeedClic: Wood Cutting Wheel. (SC544)
  • With carbide coating for cutting wood and laminate (Not metal)
26150550JB
1 piece
£16.00*
DREMEL® Comfort Guard (550(1))
  • Clear and simple solution for redirecting debris and sparks
Shank diameter
3.2 mm
Working diameter
13.0 mm
Working height
13.0 mm
Working length
13.0 mm
Steel with Tungsten Carbide Abrasive
Shape
Drum
Mandrel use
No Mandrel Needed
Grit
60
Maximum RPM
35,000 1/min
4053423238716
26150408DM
A 408DM sanding accessory on a white background
Delivery details
  • 1x 408DM sanding band/hole drill
22 GBP
