Sanding
Sanding Band & Mandrel 6,4 mm 60 grit (430)
Sanding Band & Mandrel 6,4 mm 60 grit Sanding Band & Mandrel 6,4 mm 60 grit
Small sanding mandrel and sanding band (Grit P60)
£6.50* RRP incl. VAT
What can you do with it?
Sanding bands will generally remove finish and material (wood or other soft material). These bands are also used for (rough) shaping and smoothing or rust removal from metal. If you want to remove just finish, consider something less aggressive like a flap wheel (no. 502 or 504), or a buff like the no. 511S/512S or 511E/512E.
How to use?
The physical appearance of the band indicates what grit it is, the larger the bumps the lower the grit.
Sanding bands are available in 120 and 60 grit. The lower the grit, the more material is removed.
Use the sides of the bands to do the sanding.
Sanding bands will wear out and are replaceable by loosening the screw on the top of the drum or using the DREMEL exclusive EZ Speedclic sanding drum, for even faster band replacement.
Materials to use on
These bands can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel.
Can shape rubber surfaces
Recommended speed
Hardwood 10-35000
Softwood 10-35000
Aluminium 35000
Brass 35000
Ceramic 10-35000
Copper 25-35000
Plastic 10-20000
Stone 10-35000
Shell 10-35000
Steel 35000
Example of usage
Technical details for Sanding Band & Mandrel 6,4 mm 60 grit (430)
  • Plywood Plywood
  • Softwood Softwood
  • Chipboard Chipboard
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Copper Copper
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
Technical specifications
Shank diameter
Working diameter
Accessory length
36,0 mm
Grit
60
6,0 mm
Maximum RPM
6,0
Height
32,0
Package Contents
2 pieces
Variations
Delivery details: Sanding Band & Mandrel 6,4 mm 60 grit (430)
Product box length, 1.8 cm
Product box height, 10 cm
Product box width, 5 cm
26150430JA
8710364045167
Recommended products:
Multipurpose Set
£19.00* RRP incl. VAT
