Sanding
Sanding Band Variety Kit 13mm (771B02)
Sanding
Comprehensive sanding band set for shaping, smoothing, and surface prep.
  • Expand your project possibilities with 48 sanding bands in 3 grit levels (60, 120, 240), crafted for a variety of uses.
  • Includes 2 mandrels for easy and secure band attachment, adding convenience to your projects.
  • From rough shaping to detailed finishing, these bands work effectively on wood, fiberglass, plastics, aluminum, and steel.
See all variations
22.5 GBP
Plywood
Softwood
Chipboard
Hardwood
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Copper
Rubber
Plastic
Plexiglass
Product Overview
The Dremel 771B-02 Variety Kit broadens your Multi-Tool's versatility, transforming it into an essential tool for sanding and finishing. With multiple grits included, you’ll have the perfect band for every stage of your work.
What can you do with it?
Effortlessly handle tasks like shaping wood, smoothing plastics, or removing rust from metal surfaces. These sanding bands are also perfect for fine-tuning rubber and other soft materials, giving you control over every detail of your project. • 2 x 430 Sanding Band 13 mm (60 Grit) including Mandrel – Great for removing material • 14 x 431 Sanding Band 13mm (60 Grit) – Perfect for tackling tougher surfaces and layers. • 16 x 438 Sanding Band 13mm (120 Grit) – Excellent for prepping wood, cleaning plaster, and achieving smooth finishes. • 16 x 446 Sanding Band 13mm (240 Grit) – Ideal for polishing and adding detailed touches to wood and painted surfaces.
How to Use.
Attach a sanding band to the 430 Sanding Drum Mandrel, secure it to your Dremel Multi-Tool, and select the appropriate speed for your material. Let the tool glide over the surface without pressing too hard for the best results. For added confidence, practice on scrap material before beginning your project.
Recommended speed (RPM).
• Hardwood & Softwood: 20,000–30,000 • Plastic: 15,000–20,000 • Aluminum & Steel: 15,000–25,000
Shank diameter
Working diameter
Grit
Package contents
Price
26150771JA
3.2 mm
13.0 mm
1 piece
£22.00*
  • Comprehensive sanding band set for shaping, smoothing, and surface prep.
2615040732
3.2 mm
13.0 mm
1 piece
£3.70*
Sanding Band & Mandrel 13 mm grit 60 (407)
  • For (painted) material removal / shaping of wood and plastics.
2615040832
3.2 mm
13.0 mm
6 pieces
£3.20*
Sanding Band 13 mm 60 grit (408) 6 pieces
  • Large sanding band for sanding of wood and plastics
26150408DM
3.2 mm
13.0 mm
1 piece
£21.50*
Sanding band and hole drill DREMEL® MAX (408DM)
  • Sanding hard & soft woods, composites, fiberglass, Masonite boards, rigid foam, and more. Drilling soft wood and ceramic wall tile.
26150430JA
3.2 mm
6.4 mm
2 pieces
£8.00*
Sanding Band & Mandrel 6,4 mm 60 grit (430-2) 2 pieces
  • Small sanding mandrel and sanding band (Grit P60)
2615043132
3.2 mm
6.4 mm
6 pieces
£3.20*
Sanding Band 6,4 mm 60 grit (431) 6 pieces
  • Small sanding band for detailed sanding of wood and plastics
2615043232
3.2 mm
13.0 mm
6 pieces
£3.20*
Sanding Band 13 mm 120 grit (432) 6 pieces
2615043832
3.2 mm
6.4 mm
6 pieces
£3.20*
Sanding Band 6,4 mm 120 grit (438) 6 pieces
26150770JA
3.2 mm
6.4 mm
1 piece
£22.00*
DREMEL® 770B-02 (770B-02)
  • Versatile sanding band kit for shaping, smoothing, and rust removal.
Shank diameter
3.2 mm
Working diameter
13.0 mm
Accessory length
36.0 mm
Aluminum Oxide
Shape
Band
Mandrel use
Use with either Dremel EZ407SA/SC407 or 407 mandrels
Grit
60 / 120 / 240
Maximum RPM
0,035 1/min
4059952729435
26150771JA
Related Media Sanding Band Variety Kit 13mm
Delivery details
  • 2x 430 Sanding Band 13 mm (60 Grit) including mandrel
  • 14x 431 Sanding Band 13mm (60 Grit)
  • 16x 438 Sanding Band 13mm (120 Grit)
  • 16x 446 Sanding Band 13mm (240 Grit)
  • Product box length, 15.24 cm
  • Product box height, 10.16 cm
  • Product box width, 6.43 cm
  • Gross weight, 0.09 kg
22.5 GBP
