NOT SELLABLE
Sanding
Retired Products
Sanding Disc 240 grit (413) 36 pieces
NOT SELLABLE
Sanding
Retired Products
See all variations
2.8 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Sandwich material
Steel-general
Metal pipes
Veneered woods
Plastic
Brass
Copper
Softwood
Soft Metal
Fiberboard
Laminates
Plywood
Hardwood
Chipboard
What can you do with it?
Common uses for the Dremel sanding disc include smoothing and shaping wood or removing paint. is great for (smooth) flat and edge sanding of soft materials such as wood and fiberglass Dremel sanding discs have a finer grit than Dremel sanding bands. Also used for rust removal The lower the grit, the more material removal. The SC411 (grit: 60) and SC413 (grit: 240) are from the Dremel Exclusive EZ Speedclic family. This makes accessory changes easy as PULL - TWIST - RELEASE.
How to use?
These discs are best used with the Dremel tool facing towards the work piece, and are flexible to accommodate for any curves on the project. We recommend using mainly the center of the disc for maximum results.
Sanding discs will wear out and are replaceable by removing the mandrel.
Materials to use on
These disks can be used to sand / smooth softer materials like hardwood, softwood, plastic, fiberglass, aluminum but also for rust removal of metal types, like steel.
Recommended speed
Hardwood 10-35000 Softwood 10-35000 Aluminium 35000 Brass 35000 Copper 25-35000 Plastic 10-20000
Shank diameter
Working diameter
Grit
Package contents
2615041332
3.2 mm
19.0 mm
36 pieces
  • For (smooth) flat and edge sanding of soft materials such as wood or rust removal
2615S411DM
38.0 mm
1 piece
EZ SpeedClic Sanding Discs DREMEL® MAX (SC411DM)
  • 20Xlonger life 3-piece sanding discs set.
2615041132
3.2 mm
19.0 mm
36 pieces
Sanding Disc 180 grit (411) 36 pieces
Shank diameter
3.2 mm
Working diameter
19.0 mm
Silicon Carbide Abrasive with Rubber reinforced
Shape
Disc
Mandrel use
Use with 402 Screw Mandrel
Grit
240
Maximum RPM
20,000 1/min
36
36
Suitable Dremel devices
Multi-Tools
Retired Products
8710364008445
2615041332
413_Dremel_sanding disc
Delivery details
  • Product box length, 1.8 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
2.8 GBP
