Cutting
Dremel (SC456-1)
NOT SELLABLE
SC456 metal cutting wheel
SC456 metal cutting wheel SC456 metal cutting wheel
Reinforced for durability, make cuts in e.g. hardened steel
What can you do with it?
For slicing and cutting metal including hardened steel. Ideal for cutting, grooving and trimming all kinds of metal. Cut-off wheels make it easy to cut bolts or screws or make slots in rusted or stripped bolts and screws for removal with a screwdriver. Reinforced with fiberglass for increased durability. The SC409 wheels have a thickness of just 0.75 mm for even thinner cuts.
How to use?
Use with SC402 Mandrel. The Dremel exclusive Easy Speedclic (SC) mechanism, makes wheel changing keyless, easy and fast: PULL - TWIST – RELEASE
Cutting wheel
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron or even hardened steel.
Recommended speed
Aluminium 35000
Brass 35000
Copper 35000
Steel 35000
Example of usage
Technical details for SC456 metal cutting wheel (SC456-1)
  • Metal pipes Metal pipes
  • Sheet Metal Sheet Metal
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
Max working depth
14,0 mm
Maximum RPM
Variations
Recommended products:
EZ SpeedClic Cutting Accessory Set
£28.00* RRP incl. VAT
