Retired Products
Dremel (231)
Converts your Dremel tool into a bench mounted tool for precise routing, shaping and sanding.Plastic knobs for easy tool assembly and depth adjustment.Smooth table surface to slide your workpiece easily over the table.Slot, groove, sand and trim edges.3-way adjustable fence for accurate working result.Worktable 203 x 152 mm.Adjustable, transparent router bit guard enables safe working.
Technical details for Shaper / Router Table (231)
Technical specifications
24 cm
20 cm
Depth
Suitable Dremel devices
Multi-Tools
Retired Products
2615023132
8710364016891
Delivery details: Shaper / Router Table (231)
Shaper/Router Table
Product box length, 17.2 cm
Product box height, 25.5 cm
Product box width, 21 cm
2615023132
8710364016891
8710364016891
