Grinding / Sharpening
Silicon Carbide Grinding Stone 19,8 mm (85422)
Thin grinding stone. For grinding non-ferrous materials like stone
  • Ideal for sharpening, deburring and general purpose grinding on harder materials
  • Designed to work well on stone, glass, ceramic, porcelain, gemstones and non-ferrous metals
  • Great for grinding and etching
3.7 GBP
Aerated Concrete
Concrete
Drywall/Plasterboard
Brass
Copper
Soft Metal
Porcelain
Brick
Marble
Granite
Ceramic
Glass
What can you do with it?
For sharpening, deburring and general purpose grinding. Typical uses include removal of stilt marks and excess glaze, sharp edges on tiles and engraving on glass. These grinding stones are tougher than aluminum oxide points, these are made especially for use on hard materials such as glass and ceramics.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
To grind and etch stone, glass, ceramics, porcelain and non-ferrous metals
Recommended speeds (RPM):
Ceramic 35.000 Glass: 35.000 Stone: 10.000 - 15.000 Shell: 10.000 - 15.000
Package contents
Price
2615542232
1 piece
£3.70*
  • Thin grinding stone. For grinding non-ferrous materials like stone
26155602JA
3 pieces
£9.50*
Silicon Carbide Grinding Stone (85602) 3 pieces
  • Thin, small grinding stone. For grinding non-ferrous materials like stone
26153322JA
3 pieces
£10.50*
Silicon Carbide Grinding Stone 3,2 mm (83322) 3 pieces
  • Small, bullet shaped, silicon carbide grinding stone.
26154922JA
3 pieces
£10.50*
Silicon Carbide Grinding Stone 4,8 mm (84922) 3 pieces
  • Small, cone shaped silicon carbide grinding stone.
Shank diameter
Working diameter
19,8 mm
Accessory length
40,0 mm
Silicon Carbide
Shape
Disc
Mandrel use
No Mandrel Needed
19,0 mm
19,0 mm
Height
Suitable Dremel devices
Retired Products
Multi-Tools
8710364016853
2615542232
Dremel  accessory 85422_Silicon Carbide Grinding Stone 19,8 mm
Delivery details
  • Product box length, 2 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
3.7 GBP
