Grinding/sharpening
Silicon Carbide Grinding Stone 19,8 mm (85422)
Thin grinding stone. For grinding non-ferrous materials like stone
£3.00*
RRP incl. VAT
What can you do with it?
For sharpening, deburring and general purpose grinding. Typical uses include removal of stilt marks and excess glaze, sharp edges on tiles and engraving on glass.
These grinding stones are tougher than aluminum oxide points, these are made especially for use on hard materials such as glass and ceramics.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
To grind and etch stone, glass, ceramics, porcelain and non-ferrous metals
Recommended speeds (RPM):
Ceramic 35.000
Glass: 35.000
Stone: 10.000 - 15.000
Shell: 10.000 - 15.000
Glass: 35.000
Example of usage
Technical details for Silicon Carbide Grinding Stone 19,8 mm (85422)
Aerated Concrete
Concrete
Drywall/Plasterboard
Brass
Copper
Soft Metal
Porcelain
Brick
Marble
Granite
Ceramic
Glass
Technical specifications
Shank diameter
Working diameter
19,8 mm
Accessory length
40,0 mm
19,0 mm
19,0 mm
Height
Maximum RPM
25.000 1/min
Package Contents
1 piece
Suitable Dremel devices
Retired Products
Multi-Tools
2615542232
8710364016853
Similar Accessories (3)
Delivery details: Silicon Carbide Grinding Stone 19,8 mm (85422)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
2615542232
8710364016853
8710364016853
