Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Grinding / Sharpening
Retired Products
Silicon Carbide Grinding Stone (85602-3) 3 pieces
Retired Products
7.33 GBP
Payment options
VISA cardMasterCardPayPalKlarnaApple PayGoogle Pay
Aerated Concrete
Concrete
Drywall/Plasterboard
Brass
Copper
Soft Metal
Porcelain
Brick
Marble
Granite
Ceramic
Glass
What can you do with it?
For sharpening, deburring and general purpose grinding. Typical uses include removal of stilt marks and excess glaze, sharp edges on tiles and engraving on glass. These grinding stones are tougher than aluminum oxide points, these are made especially for use on hard materials such as glass and ceramics.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
To grind and etch stone, glass, ceramics, porcelain and non-ferrous metals
Recommended speeds (RPM):
Ceramic: 35.000 Glass: 35.000 Stone: 10.000 - 15.000 Shell: 10.000 - 15.000
Package contents
Price
26155602JA
3 pieces
£9.50*
  • Thin, small grinding stone. For grinding non-ferrous materials like stone
26153322JA
3 pieces
£10.50*
Silicon Carbide Grinding Stone 3,2 mm (83322-3) 3 pieces
  • Small, bullet shaped, silicon carbide grinding stone.
26154922JA
3 pieces
£10.50*
Silicon Carbide Grinding Stone 4,8 mm (84922-3) 3 pieces
  • Small, cone shaped silicon carbide grinding stone.
2615542232
1 piece
£3.70*
Silicon Carbide Grinding Stone 19,8 mm (85422)
  • Thin grinding stone. For grinding non-ferrous materials like stone
Shank diameter
3.2 mm
Working diameter
10.3 mm
Accessory length
39.0 mm
10.0 mm
10.0 mm
Height
38.0 mm
Maximum RPM
20,000 1/min
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044979
26155602JA
2 pieces Silicon Carbide Grinding Stone (85602)
Delivery details
  • 3 pcs
  • Product box length, 2 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
7.33 GBP
