Cutting
Spiral Cutting Bits Multipurpose (561-3) 3 pieces
Cutting
For 'free' cutting in softer materials like soft wood, drywall and plastics
  • Cuts wood, plastic, fiberglass, drywall, laminate and aluminum and vinyl siding
  • High-speed cutter
  • Ideal for multi-purpose cutting
See all variations
13.8 GBP
Hardwood
Softwood
Veneered woods
Drywall/Plasterboard
Soft Metal
Plastic
Plexiglass
What can you do with it?
Best for cutting and drilling in soft materials such as soft woods (less than 12mm thick) and plastics. Great to go freehand to create the shapes you like.
How to use?
We recommend to use this bit with the Dremel Multipurpose Cutting Attachment, because it’s designed to help you maintain depth during the application. It’s important that the depth of the guide supports the cutting blade extending beyond the material by about 0.6 cm. (.25”). If the bit extends out too far beyond the material, it can be more difficult to control and can actually snap the bit.
Best control of the bit occurs when moving in a clockwise direction. Begin the cut at a 45 degree angle and then bring the accessory to 90 degrees.
The tool should be set at a high speed, the feed rate of the material or the tool through the material should be slow and gradual. Too much pressure will cause this accessory to get “red hot.”
Using the tip of the bit is not the best way to cut – we recommend using the sides of the bit, where the full cutting capacity of the fluting can be put to use.
Materials to use on
Soft materials like soft woods (less than 12mm thick), plastics, glass fibers and thin foils of aluminum.
Recommended speed
Aluminum 20.000 – 35.000 RPM Hardwood 20.000 – 35.000 RPM Softwood 20.000 – 35.000 RPM Plastic 10.000-15.000RPM
Working diameter
Package contents
Price
26150561JA
3.2 mm
3 pieces
£13.50*
  • For 'free' cutting in softer materials like soft wood, drywall and plastics
2615056232
3.2 mm
1 piece
£18.50*
Spiral Cutting Bits (562)
  • For 'free' cutting in wall tiles (not floor tiles)
26150566JB
1 piece
£20.50*
DREMEL® Wall Tile Cutting Kit (566)
  • Make controlled cuts in any shape in wall tiles
Shank diameter
3.2 mm
Working diameter
3.2 mm
Working length
30 mm
Accessory length
65.0 mm
High Speed Steel
Shape
Spiral
Mandrel use
No Mandrel Needed
3.0 mm
Maximum RPM
35,000 1/min
3.0 mm
Height
62.0 mm
3
3
Suitable Dremel devices
Retired Products
Multi-Tools
8710364045150
26150561JA
Three Spiral Cutting Bits Multipurpose for free cutting in softer materials like soft wood, drywall and plastics
Delivery details
  • 3 pcs
  • Product box length, 1.5 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
13.8 GBP
