Cutting
Spiral Cutting Bits Multipurpose (561)
Spiral Cutting Bits Multipurpose Spiral Cutting Bits Multipurpose
For 'free' cutting in softer materials like soft wood, drywall and plastics
£7.90* RRP incl. VAT
What can you do with it?
Best for cutting and drilling in soft materials such as soft woods (less than 12mm
thick) and plastics. Great to go freehand to create the shapes you like.
How to use?
We recommend to use this bit with the Dremel Multipurpose Cutting Attachment, because it’s designed to help you maintain depth during the application. It’s important that the depth of the guide supports the cutting blade extending beyond the material by about 0.6 cm. (.25”). If the bit extends out too far beyond the material, it can be more difficult to control and can actually snap the bit.
Best control of the bit occurs when moving in a clockwise direction. Begin the cut at a 45 degree angle and then bring the accessory to 90 degrees.
The tool should be set at a high speed, the feed rate of the material or the tool through the material should be slow and gradual. Too much pressure will cause this accessory to get “red hot.”
Using the tip of the bit is not the best way to cut – we recommend using the sides of the bit, where the full cutting capacity of the fluting can be put to use.
Materials to use on
Soft materials like soft woods (less than 12mm thick), plastics, glass fibers and thin foils of aluminum.
Recommended speed
Aluminum 20.000 – 35.000 RPM
Hardwood 20.000 – 35.000 RPM
Softwood 20.000 – 35.000 RPM
Plastic 10.000-15.000RPM
Example of usage
Technical details for Spiral Cutting Bits Multipurpose (561)
  • Sandwich material Sandwich material
  • Veneered woods Veneered woods
  • Brick Brick
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Ceramic Ceramic
  • Softwood Softwood
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Attachment Attachment
Technical specifications
Shank diameter
Working diameter
Working length
30 mm
Accessory length
65,0 mm
Maximum RPM
Height
62,0 mm
Package Contents
3 pieces
Variations
Delivery details: Spiral Cutting Bits Multipurpose (561)
Product box length, 1.5 cm
Product box height, 10 cm
Product box width, 5 cm
26150561JA
8710364045150
