Retired Products
Carving / Engraving
Structured Tooth Tungsten Carbide Cutter coned 7,8 mm (9934)
Retired Products
Carving / Engraving
See all variations
20.74 GBP
Payment options
Carbon
Leather
Rubber
Drywall/Plasterboard
Brick
Brass
Soft Metal
Softwood
Ceramic
Hardwood
Hardened Steel
Stainless Steel
Cast iron
Plastic
Shank diameter
Working diameter
Accessory length
Package contents
Price
2615993432
7.8 mm
40.0 mm
1 piece
£27.00*
- Very tough bit, for material removal of e.g. fiberglass, wood or ceramic tile.
Order number2615993432
EAN-Code8710364008575
2615993132
6.4 mm
45.0 mm
1 piece
£25.00*
Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm (9931)
Order number2615993132
EAN-Code8710364008544
2615993632
19.0 mm
45.0 mm
1 piece
£29.50*
Structured Tooth Tungsten Carbide Cutter wheel shaped 19 mm (9936)
Order number2615993632
EAN-Code8710364008599
Shank diameter
Working diameter
7.8 mm
Accessory length
40.0 mm
8.0 mm
8.0 mm
Height
40.0 mm
Maximum RPM
35,000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364008575
2615993432
EAN Code8710364008575
Delivery details- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
20.74 GBP
