Carving / Engraving
Dremel (9931)
Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm
Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm
Very tough bit, for material removal of e.g. fiberglass, wood or ceramic tile.
£25.00* RRP incl. VAT
Technical details for Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm (9931)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Drywall/Plasterboard Drywall/Plasterboard
  • Brick Brick
  • Brass Brass
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Ceramic Ceramic
  • Hardwood Hardwood
  • Aluminium Aluminium
  • Cast iron Cast iron
  • Plastic Plastic
Technical specifications
Shank diameter
Working diameter
Accessory length
45,0 mm
4,0 mm
4,0 mm
Height
45,0 mm
Maximum RPM
Variations
Delivery details: Structured Tooth Tungsten Carbide Cutter spear shaped 6,4 mm (9931)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615993132
8710364008544
