Carving/Engraving/Routing
Structured Tooth Tungsten Carbide Cutter wheel shaped 19 mm (9936)
Structured Tooth Tungsten Carbide Cutter wheel shaped 19 mm Structured Tooth Tungsten Carbide Cutter wheel shaped 19 mm
Very tough bit, for material removal of e.g. fiberglass, wood or ceramic tile.
£27.00* RRP incl. VAT
Example of usage
Technical details for Structured Tooth Tungsten Carbide Cutter wheel shaped 19 mm (9936)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Drywall/Plasterboard Drywall/Plasterboard
  • Brick Brick
  • Brass Brass
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Ceramic Ceramic
  • Hardwood Hardwood
  • Aluminium Aluminium
  • Cast iron Cast iron
  • Plastic Plastic
Technical specifications
Shank diameter
Working diameter
19,0 mm
Accessory length
45,0 mm
19,0 mm
19,0 mm
Height
45,0 mm
Maximum RPM
Package Contents
1 piece
Variations
Delivery details: Structured Tooth Tungsten Carbide Cutter wheel shaped 19 mm (9936)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
2615993632
8710364008599
