Carving / Engraving
Tungsten Carbide Cutter ball tip 3,2 mm (9905)
Carving / Engraving
See all variations
15 GBP
Carbon
Leather
Rubber
Drywall/Plasterboard
Brick
Brass
Soft Metal
Softwood
Ceramic
Hardwood
Hardened Steel
Stainless Steel
Cast iron
Plastic
Shank diameter
Working diameter
Accessory length
Package contents
Price
2615990532
3.2 mm
38.0 mm
1 piece
£14.50*
- Ball shaped bit, one of Dremel's toughest engraving/carving bits.
Order number2615990532
EAN-Code8710364008643
2615990132
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter square tip 3,2 mm (9901)
- Cylindrical shaped bit, One of Dremel's toughest engraving/carving bits
Order number2615990132
EAN-Code8710364008605
2615991032
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter spear tip 3,2 mm (9910)
- Cone shaped point bit, one of Dremel's toughest engraving/carving bits.
Order number2615991032
EAN-Code8710364008674
2615990332
3.2 mm
39.0 mm
1 piece
£14.50*
Tungsten Carbide Cutter pointed tip 3,2 mm (9903)
- Cylindrical shaped bit with round tip. One of Dremel's toughest engraving/carving bits.
Order number2615990332
EAN-Code8710364008629
Shank diameter
Working diameter
3.2 mm
Accessory length
38.0 mm
Tungsten Carbide (C-2)
Shape
Ball nose
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
39.0 mm
Maximum RPM
30,000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364008643
2615990532
EAN Code8710364008643
Delivery details- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
15 GBP
